PIDFF autotune
  • Industrial Automation
  • PIDFF autotune
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
PLC-Easy
PLC-Easy
Posted: ‎2021-11-08 07:59 AM
2320
PIDFF autotune
Good day. I have a problem that I am trying to solve in a week. I am a student. I am studying software Unity Pro. My problem is that I cannot adjust the parameters of the PIDFF block using the AUTOTUNE block. The coefficients of the PIDFF block remain unchanged, namely equal to 0.Good day. I have a problem that I am trying to solve in a week. I am a student. I am studying software Unity Pro. My problem is that I cannot adjust the parameters of the PIDFF block using the AUTOTUNE block. The coefficients of the PIDFF block remain unchanged, namely equal to 0. I also tried to see an example of the PIDFF EFB - Tank Level Control Example provided by the company, but it cannot be downloaded. I would be immensely grateful to you if you could help me with this problem. I need a successful example of PIDFF autotuning using AUTOTUNE.
  • Smart Operations
  • m340
  • Programing
john_m
Ensign john_m
Ensign
Posted: ‎2021-11-09 08:12 AM
It is not exactly the appropriated  answer, but you can try Relaxc available on scheinder.se , It is better and easier than to use a pid, IMC, PFC, MPC, etc .
You have a new tuning there
https://www.researchgate.net/publication/354721952_Relaxc_revisited_Tuning_experiment_cases
video
https://youtu.be/wePez3n0h-E
https://www.researchgate.net/publication/344219560_Relaxc_Bibliography_v2
If you want more information, contact me
regards
