Posted: 2021-10-20 10:01 PM . Last Modified: 2021-10-25 04:41 AM
Hi
I need help regarding the connection between IFM and PLC's.
I have Masterpact MTZ1-10 H1 and i have it successfully connected to lv434000 modbus.
I now need wiring diagrams or something to connect it to a unitronics plc.
So the modbus uses rj45 and i think it outputs it's thing trough rs485.
Posted: 2021-10-20 10:21 PM
Hi MikyE,
You could find the Pin wiring of the RJ45 plug in the instruction sheet.
You need normaly at every SE Product for RS485 Modbus Pin 4 and Pin 5
If you use a standard patch cable you have to use the blue and the blue with wire.
For easier wiring you could use
or
I did not know which kind of plug you need on the Unitroncs HMI/PLC.
You could find additional adapter cables in the SE Harmony HMI offer.
Catalog HMIST6 (adapter cable page 22..24)
Posted: 2021-11-01 12:04 AM
@Bastian_Schmitz wrote:Hi MikyE,
or
RJ45 Open Style cable slope game
Thank you, this question was also relevant to me.
