Posted: 2025-09-19 09:22 PM
Hello Everyone,
Is there a way to create more that 512 screen objects in OTE. Is it kind of like license to get more screen object?
Posted: 2025-09-21 09:41 PM
Good day,
The P6 can have 2048 but on the ST6 only 512
If you use EOTE 4 then you have a new feature to merge shapes
To reduce the number of objects on a page you can select all the objects without any variable links (static objects) and merge them into 1 object.
In older versions you can take a screencap of the screen with only the static objects and re-insert it as an single image.
Both methods would need a bit of tinkering to get perfect but they can reduce the number of objects significantly.
Hennie
