Posted: 2024-01-09 04:35 PM
Dear all expert,
I'm using EcoStruxure Machine SCADA Expert 2022 SP1. Currently I need to generate a report base on the data from MS SQL database. Would like to get some advise how to achieve this as I have tried to use the build in language to quiries with curly bracket. Unfortunely it was not able to retrieve that.
Any advise would be much apprrciated.
Thanks in advance.
From,
Wai Lip
Posted: 2025-09-21 12:44 AM
Hi, even I have tried to generate reports using HTML and CSV considering DEMO project provided by schneider but unfortunately after writing the script if I create the RTF file script only then the report shall give me output, and the output is giving the /par ETC texts which i am not sure if its correct, if you know about this please help me.
ahisam@microcontrol.ae is my mail id.
Thanks.
