Electronic over current relay
Send InviteCancel
Posted: 2025-09-1006:00 AM
Can I use electronic over current relay (EOCR-DS3) that has three current transformers to protect single phase motor?
And if it valid. When we use thermal over load relay for 1 phase motor we connect Line through its two poles and connect neutral to the third. Is EOCR the same concept?
