Posted: 2024-10-06 10:57 PM
I have HMIST6700 HMI. I need to show and control data from 4 different PLCs over modbus Ethernet. Is it possible using different symbol links in operator terminal expert. What is the maximum limit a single HMI6700 can communicate with different PLCs over modbus ethernet protocol?
Posted: 2024-10-11 01:56 AM
Hi
Yes you can use diferent symbol-links in EOTE.
If the HMI act as Slave then the max. connection is 20 and if the HMI act as Master the max. connection is 64.
Greetings
