Posted: 2024-01-25 07:11 PM
Hi guys,
I am new working on EcoStruxure Control Expert Classic. I just trying to create a rung dedicated to move a value to a variable with the MOVE instruction. I have the following issue: e1053 input variable ' Cfg_OnDelay ' must not be assigned. I don't understand why is this error showing up. Should be fine to move a value (zero in this case) to a INT variable. If somebody could help me I would appreciate it so much. Please see attached.
Thanks in advance,
Posted: 2024-01-30 07:58 AM
If this variable is assigned or aliased to an input module, or if it is assigned a %IW address, it is a read only variable. You cannot directly write to it, but you can insert a value using the WRITE_INPUT_INT instruction. This is in Control Expert's I/O Management library, Simulation family.
Posted: 2024-01-31 06:54 AM
Hi Jerry,
Thanks for your quick response. I am creating a DFB and I assigned my variable as INPUT. I created a variable called Simulated_INT as INP in the 'Write_Input_Int' block and I have the same issue(e1053 input variable 'Cfg_OnDelay' must not be assigned). If I try to put the variable on both side( input and output) it's still the same error. Please see attached
Reidel
Posted: 2024-02-02 08:01 AM
Hi Reidel, you're still trying to write directly to Cfg_OnDelay. You can only write to that as the output of the WRITE_INPUT_INT instruction.
What is the address of the variable that is flagging it as an input?
Posted: 2024-02-05 05:49 AM
Hi Jerry,
I am just trying to move a value of zero to an input variable that I have already created in my DFB AOI_Alarm(please see attached). It is very easy what I want to do but I think I am doing something wrong. If you can share with me a picture on how to do a Move operation i will appreciate it. Thanks. Have a good day!
Reidel
Posted: 2024-02-08 07:54 AM
Now I understand, Reidel. You can put a literal value on an input pin instead of a variable. Just double click on the pin and type the value you want there. In this case it could be any integer value.
Posted: 2024-04-01 09:21 AM
Hi Jerry,
Posted: 2024-10-09 09:20 AM
Hi, could you solve it?
Posted: 2024-10-11 06:27 AM
Yes, I did it. I was using my variable as an input (read only). I changed it to <inputs/outputs> (read/write) in my DFB. That was my easy solution, but it is possible that we have other ways to avoid this error message.
