Modbus simulation in machine expert
  • Industrial Automation
  • Modbus simulation in machine expert
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Machine Expert
MedSelmi
Ensign MedSelmi
Ensign
Posted: ‎2021-06-08 05:24 AM
3
5786
I am newbie with shneider software, I am using machine expert v2.0 and I am trying to simulate my m241 project with modbus slave simulator even when I simulate 2 plcs M241 ( 2 projects) there is no data exchange via Modbus Tcp/ip.
Can you help me please? Shall I use Read_VAR or only generic modbus Tcp slave configuration ?
  • Training
  • french
  • M241
  • Machine Expert
  • modbus
  • simulation
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-06-08 08:50 PM
2
5764
I haven't used the Machine Expert platform, but typically when running code in a Simulator, field communications (including Modbus) aren't operative.
You'd need to use real hardware to get the Modbus communications working (typically).
MedSelmi
Ensign MedSelmi
Ensign
Posted: ‎2021-06-09 05:36 AM
In response to BevanWeiss
5753
Thank you for your response. I know that serial communications need real HW but with tcp/ip communications we can simulate as you see in attachment I was able to do that with Control expert v15 and modbus poll.  ControlExpert.png
  • Control Expert
  • Machine Expert
  • modbus
  • simulation
  • Как мне привязать адрес momdbus к физическому входу или выходу помогите пожалуйста например %I0.2.0 или %Q0.3.0
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-06-09 03:39 PM
In response to MedSelmi
The online manual seems to refer to simulation here
https://product-help.schneider-electric.com/Machine%20Expert/V2.0/en/exTcpUdp/index.htm#rhfulllayout...
