Modbus TCP Communication Port for - P582020 with Other Modbus Devices
  • Industrial Automation
  • Modbus TCP Communication Port for - P582020 with Other Modbus Devices
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
IslamSaid
Crewman IslamSaid
Crewman
Posted: ‎2022-11-25 02:04 AM . Last Modified: ‎2022-11-25 02:10 AM
1911
Which Port i Can use for Modbus TCP Communication for - P582020, with Other Modbus Devices, and How to Do that ?
As Following the Instruction Video, i couldn`t Find Model Family
https://www.youtube.com/watch?v=QhkIQCOyxjo
  • Connected Products
  • Smart Design & Engineering
IslamSaid
Crewman IslamSaid
Crewman
Posted: ‎2022-11-28 10:47 AM
In response to RoozeeR
Hi ,
I found the issue, Actually Slave ID, needs to be Written beside the Address, but this wasn`t mentioned either in the Help - Documents for ADDMX or the Videos.
After Adding Slave ID, it started Reading and Writing
Replies 4
RoozeeR
Lt. Commander RoozeeR Lt. Commander
Lt. Commander
Posted: ‎2022-11-25 03:13 AM
3
1897
M580 networking is configured using DTM configuration (open DTM Browser) not the Communication-Networks (this is for M340).
Refer to this video: https://www.youtube.com/watch?v=piDpLjMxmyw
You can use the IO-scanning as shown in the video, or use READ_VAR/WRITE_VAR:
https://www.youtube.com/watch?v=usLS7yuiF6s
IO-Scannin is  Limited to Modbus functions 3&16 (read/write %MW or 4xxxxx references)
Read_VAR/WRITE_VAR support more Modbus functions (see manual or help in Unity/ECE)
R.Roozee
Sr Solution Architect (SAE Master)
IslamSaid
Crewman IslamSaid
Crewman
Posted: ‎2022-11-28 01:43 AM
1863
Many Thanks Roozee.
I have used the READ_VAR & WRITE_VAR Blocks form M580, but i amn`t able to Read or Write to the slave, is there a Problem with my Setup ?
M580M580Modbus Slave - ClientModbus Slave - Client
RoozeeR
Lt. Commander
Posted: ‎2022-11-28 02:52 AM
In response to IslamSaid
1856
Remove (temporarily) the WRITE_VAR, as it's not configured properly, and set the timeout value in CONTROL[2] to 10. Timeout of 0 will "hang" the function when something is wrong.
In that case you should see CONTROL[0] changing and CONTROL[1] should become 0.
I'm not familiar with the Modbus SLAVE program, but can you try to set the Modbus Slave ID to 255?
R.Roozee
IslamSaid
Crewman IslamSaid
Crewman
Hi ,
