Is it possible to use VSD as a power supply for the CNC machines?
  • Industrial Automation
  • Is it possible to use VSD as a power supply for the CNC machines?
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Posted: ‎2019-09-17 03:20 AM . Last Modified: ‎2019-12-02 05:49 AM
2351
dears;
 is it possible to use VSD as a power supply for the CNC machines ,
for example , i need  to use ATV650D55N4 as a regulated power supply for a CNC machine type ehrt holecut 40-10 cnc , is it accepted ?
regards
  • Asset Performance
  • Smart Operations
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2019-12-02 01:23 PM
Are you think to use a VSD for a single phase to three phase converter?
In general, I would not recommend this approach.  VSDs are quite complex devices, and generally expect certain things from their field systems (i.e. short circuits incredibly unlikely, thermal model equivalent to a large lump of steel, inductive loads).
If you are disconnecting loads suddenly (as would happen if a CNC machine is switching its own 240/415 power) the VSD will likely trip or produce unreliable voltages/frequencies.
A VSD is really a 'Variable Speed Drive', it's not intended for us as a power supply.
