EcoStruxure operator terminal expert animation problem
  • Industrial Automation
  • EcoStruxure operator terminal expert animation problem
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Posted: ‎2019-11-11 05:01 AM
2
8916
Hello
I am using ecoStruxure operator terminal expert.
Is it posible to make an animation of object in correlation of variable value.
For example.
I am having a switch object and i am using it for input for var1 to control motor. Now i want to animate switch color by the value in Var2. Is this posible? I need this for indication if motor is runing in auto or manual mode and if it is standing or error, so at least 4 diferent status. And also i want to change texts for the sam status.
  • App Analytics & Services
  • VijeoXD
Lukas
Ensign Lukas Ensign
Ensign
Posted: ‎2019-11-20 05:48 AM
You may use convertors for this task: Workaround Color- and Text ressources with EcoStruxure Operator Terminal Expert V3
Lukas
Ensign Lukas Ensign
Ensign
TomDroll
Lt. Commander TomDroll Lt. Commander
Lt. Commander
Posted: ‎2019-11-21 03:09 AM
Hi, you can BIND a  variable for the ON and OFF state, of the switch - Properties dialog ->Shape->Basic then Off or On state Fill (or Border) color pallet.
See attached screen shot.
Tom Droll
