Send InviteCancel
This is lacking in full details, but if you combine the information that it provides at the end with the information available from the Driver DDK documentation then it should get you there.
Essentially copy the appropriate files (i.e. the driver and module) into the Program Files\Schneider Electric\ClearSCADA folder, and then install the registry file, and then restart your ClearSCADA server.
Lead Control Systems Engineer for Alliance Automation (VIC). All opinions are my own and do not represent the opinions or policies of my employer, or of my cat..
