How can I configure the HSP on an Altivar 320 to change dynamically on potentiomer based on digital inputs.
  • Industrial Automation
  • How can I configure the HSP on an Altivar 320 to change dynamically on potentiomer based on digital inputs.
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
alexmtnz
Crewman alexmtnz
Crewman
Posted: ‎2024-11-18 11:56 AM
Good Afternoon
I currently have an Altivar 320 configured to do the following:
  1. DI1: When this digital input is activated, the motor runs forward, and the speed is controlled via a potentiometer.
    • The minimum frequency (LSP) is set to 6 Hz.
    • The maximum frequency (HSP) is set to 60 Hz.
This works correctly.
What I need to add is:
2. DI2: When activated, the maximum frequency should change to 45 Hz, adjustable between 6 Hz and 45 Hz using the potentiometer.
3. Similarly:
  • A third digital input should change the maximum frequency to 30 Hz (adjustable between 6 Hz and 30 Hz).
  • Another digital input should limit the maximum frequency to 15 Hz (adjustable between 6 Hz and 15 Hz).
How can I configure this on the Altivar 320? Is it necessary to use custom logic, or is there a straightforward way to set this up through the drive's menu?
  • Process Automation Talks
Replies 0
