Posted: 2022-07-24 01:09 PM
Hello, is there any option of factory reset of this display?
I have forgotten my password.
Thank you
Posted: 2022-07-27 12:46 AM
Hi Petr,
here is webhelp for Operator Display for EcoStruxure Buillding Operation (what you use):
Jenda
Posted: 2022-07-30 01:25 AM
they write on the second point of the procedure this:
- On back of the Operator Display, in port USB-2 , connect a USB On The Go cable (OTG, USB-Micro-B to USB-A).
I have connect one side of the cable to Operator Display, but what can I do with the other side? Should Iconnect it to the PC or leave it inconnected?
I have tried both but without success.
TY
Posted: 2025-12-21 12:48 PM
I tried the procedure you suggested and it worked. However, I noticed that my development system is now set to System Logic instead of EOTE.
I need to use EOTE in order to download and manage my projects on the EcoStruxure Operator Terminal.
Could you please let me know how I can switch the system back to EOTE and correctly download my projects to the terminal?
Thank you very much for your support.
Best regards,
Posted: 2026-01-05 11:11 PM
Contact your local Level 2 support, they should have the possibility to restore the Firmware.
