Ecostruxure Operator Terminal Expert 3.2 How to access one bit of a Symbol linked memory word (i.e %MW10) to use for a switch variable?
  • Industrial Automation
  • Ecostruxure Operator Terminal Expert 3.2 How to access one bit of a Symbol linked memory word (i.e %MW10) to use for a switch...
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Operator Terminal Expert 3.1
Steve_P
Crewman Steve_P
Crewman
Posted: ‎2021-03-12 10:01 PM
8390
Hi all,
I know there is probably a simple solution, but I have searched everywhere for it and can't find the answer.
I have an existing M221 PLC running a STP,  which has a failing HMI that is in need of replacement (operator accident, damaged the screen) We have decided to replace it with a HMIST6500 screen and I'm in the process of changing over the code from the old Vijeo designer to the new EOTE code.
I have successfully set up the symbol link and have a list of all the tags with names etc - all good. However I have discovered that the M221 code has been written with a large proportion of the bool variables (eg, start, stop, manual, auto, forward, reverse etc) stored in words, with the idea that each word relates to a particular motor or pump.
However I have not been able to find out how to access these individual bits within the EOTE software, so far I have tried:
STPM221.Memory_Words.MW_10..3.Value
STPM221.Memory_Words.MW_10:3.Value
%MW10:X3
%MW10.3
All which do not work. I'm thinking that I will need to use a converter to isolate the required bit? Can someone please point me into the correct direction.
Also there were some rumours on one of the forums I was reading where it said that there is a Vigeo -> EOTE convertor in the pipeline - any news on this?
  • Smart Design & Engineering
Bastian_Schmitz
Admiral
Posted: ‎2021-03-15 06:44 AM
8362
The acces to a bit of a word is possible via Modbus FC Holding Registers through the Syntax
word.X0 = Bit0 of Word
word.X15 = Bit15 of Word
best regards
Replies 7
Bastian_Schmitz
Admiral
8363
best regards
ismailozinan
Commander ismailozinan Commander
Commander
Posted: ‎2021-03-15 10:53 AM
8356
You can find sample programme and video for %MW10:X1 at link.
this is Bit Toggle control via EOTE.
Best Regards,
Steve_P
Crewman Steve_P
Crewman
Posted: ‎2021-03-15 03:27 PM
In response to Bastian_Schmitz
Thanks for your reply,
Yes, this will work, I knew there would be a simple approach. Just needed the right minds in the same room, Haha
Cheers
Steve_P
Crewman Steve_P
Crewman
Posted: ‎2021-03-15 03:32 PM
In response to ismailozinan
Hi Ismailozinan,
Thanks for the reply, especially the effort you have put into the video.
Appreciate your help
Both answers work well, just a matter of figuring out which suits my application best.
Great to get fast response from the Schneider Team. Cheers.
MrM580
Lieutenant | EcoXpert Master MrM580 Lieutenant | EcoXpert Master
Posted: ‎2023-02-27 07:59 AM
6628
Hi Bastian_Schmitz,
I am trying to access the bit of an internal variable (i.e. one that does not have %MW address) to turn on and off a lamp. I tried "Word.X0" but it returns error.
What is the syntax to access the individual bits of an internal variable?
See screenshot below for reference.
Thanks.
  • bit addressing
  • internal variables
  • lamp
Bastian_Schmitz
Admiral
Posted: ‎2023-02-27 08:31 AM
In response to MrM580
1
6619
A direct access to bit of a word like you show is not directly possible. You could define a specific bit position in a word as seperate variabel. In your case the best way would be to add converter. I attach a sample project from a colleague which shows how it could work.
Project_conv_extract_bit.zip
MrM580
Posted: ‎2023-02-27 09:13 AM
Thank you for your prompt solution. I have used your converter method for this case.
If I could define the bit as a separate variable as you mentioned, that would be much easier
How do I extract a specific bit position in a word as separate variable? Would it be via scripting?
