Posted: 2021-03-10 03:55 AM . Last Modified: 2021-03-10 03:56 AM
Does the new EOTE version (V3.2.0.262) support symbol link with siemens Tia-portal V16?
I tried it with a couple of different Tia-projects but can't get the Tia-symbols. Tia-portal V15.1 projects work as expected.
Is this a problem with my specific installation or is this version not supported at the moment?
Posted: 2021-03-10 11:47 PM
Did you check the ESOTE Online Help?
Regarding to the Device/PLC Connection Manual TIA V16 should also be possible.
Posted: 2021-03-11 01:33 AM
I didn't find a solution in the manual but in the meantime i copied every tag and program block in the Tia project to a new file and now it works. So no idea what went wrong with the old file but it works now.
