Downloading Vijeo designer *.vdz file through a router
  • Industrial Automation
  • Downloading Vijeo designer *.vdz file through a router
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Posted: ‎2022-04-05 03:14 AM
3
2237
I am using Vijeo designer basic 1.1. And the target HMI I use is GXU 3512.
Now my goal isto connect Vijeo designer through a VPN router and download the application into it.
I have tried using the help given in Vijeo designer. But the necessary fields appear deactivated..
Kindly help me out pleaseFields for Router IP, Control & Data TCP Port Nos appear deactivatedFields for Router IP, Control & Data TCP Port Nos appear deactivated
Rodrigo_Garcia
Commander Rodrigo_Garcia Commander
Commander
Posted: ‎2022-06-23 04:38 AM
2058
Hello @RoozeeR , could you please support on this? Thanks!
Rodrigo G.
Industrial Automation Community manager
RoozeeR
Lt. Commander RoozeeR Lt. Commander
Lt. Commander
Posted: ‎2022-06-24 01:59 AM
In response to Rodrigo_Garcia
2034
Please check if you have VJDesigner v1.1 or v1.1 demo. Note that DEMO version does not allow to connect to a device.
If you have the correct version please contact your local support desk for additional support.
R.Roozee
Sr Solution Architect (SAE Master)
Posted: ‎2022-07-13 12:12 AM
In response to RoozeeR
We are using Vijeo Designer Basic 1.1. This is the only software that is compatible with GXU-3512 that we are using.
Between the hardware and this software, the remote -download feature seems unavailable. However, this is not critically needed as we are still able to download to device on the local network. Just that it simply appears impossible to dowload over the internet.
Thanks & regards
