Data Logger DNP3 + M580
  • Industrial Automation
  • Data Logger DNP3 + M580
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
fnomendes
fnomendes Cadet
Cadet
Posted: ‎2022-02-21 02:26 PM
1369
Hello Team!
I'm working on a project that involves the DNP3 (BMENOR2200H) + BMEP584040 protocol and a data logger will be created to record the events that occurred, so I would like to know what is the maximum limit of variables that can be used in a data logger? For example, an information avalanche occurs, what is the limitation and update time?
Does someone have this information?
Thanks in advance!
  • Edge Control
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-02-22 02:06 PM
I believe this will depend a bit on the speed of the M80 processor being used, and the amount of logic that it is also running.
But in regards to the RTU module itself, the user manual has the following information.  Which suggests that it should cope with almost all applications (at least the module itself wouldn't be the bottleneck).
https://download.schneider-electric.com/files?p_Doc_Ref=PHA90072&p_enDocType=User+guide&p_File_Name=...
There may however be other module limitations, such as number of telemetry protocol points that you can configure, and such.
