Citect V6.0 Connection with S7 300 CPU
  • Industrial Automation
  • Citect V6.0 Connection with S7 300 CPU
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Citect SCADA
Mentor
Ensign Mentor
Ensign
Posted: ‎2024-07-11 06:56 AM
3280
Dear All,
I have never work with Citect SCADA, and las days i had to convert a PC (where the Citect V6.0 is installed) in Virtual machine.
The SCADA is connected with a SIEMENS PLC S7 315-2DP via Ethernet.
The vistual machine works fine, but the SCADA cannot connect to PLC. I gues there is something in connection settings, But i don´t know where is it.
All computer name and IP address are the same, only the network card name has been changed.
Please help me how to setup the connection between the Citect and PLC.
Thank you and best regards.
  • Process Automation Talks
Hennie_Smith
Lieutenant Hennie_Smith Lieutenant
Lieutenant
Posted: ‎2025-01-09 11:43 PM
In response to Mentor
2406
Hi, You need to add a PC Station in NetPro and set as type Application. Netpro must be installed and running on the Citect IO Server. After you configured the PC Station in Netpro you need to download it as well (same process as downloading to PLC. See attaced screenshot of the fields in NetPro and where they must correspond in the Citect configuration.
Replies 8
Hennie_Smith
Lieutenant
Posted: ‎2024-07-11 09:25 PM
3256
Hi, Which driver is the Citect setup to use? PSDirect or S7NT? (To check open Citect Explorer, Change to the Project Editor Menu Communications>IODevices
Mentor
Ensign Mentor
Ensign
Posted: ‎2024-07-12 05:33 AM
In response to Hennie_Smith
3231
Hi, Thank you for the comment.
It uses S7NT driver.
Hennie_Smith
Lieutenant
Posted: ‎2024-07-14 10:10 PM
3204
The S7NT driver uses the Simatic Net software from Siemens to connect to the PLC. Did you check the Simatic Net is still licensed on the virtual machine and configured?
Mentor
Ensign Mentor
Ensign
Posted: ‎2024-07-17 04:35 AM
4
3174
I have check the Simatic PG/PC interface and it is OK.
I can connect the PLC with SIMATIC MANAGER.
Please check the photos of the settings.
Thank you.Screenshot 2024-07-17 114719.pngScreenshot 2024-07-17 114746.pngScreenshot 2024-07-17 114811.pngScreenshot 2024-07-17 114827.pngScreenshot 2024-07-17 114851.pngScreenshot 2024-07-17 114908.pngScreenshot 2024-07-17 115106.png
Hennie_Smith
Lieutenant
Posted: ‎2024-07-17 10:10 PM
3160
Hi, All the info above seems correct but need the NetPRO configuration as well to be sure.
Once the configuration is complete in NetPro, it must be transferred to the PC Station. This can either be done by a file or over the Network. Provided that everything is OK, you should see your configuration from NetPro appear in the Station Configuration Editor on the Local PC.
Mentor
Ensign Mentor
Ensign
Posted: ‎2024-12-18 06:57 AM
2582
Dear Hennie,
Thank you for your reply.
Regarding the NetPRO configuration, I am not sure if everything is OK there.
In the Simatic manager, it is configured. Please find a photo of that.Screenshot 2024-12-18 155608.png
Hennie_Smith
Lieutenant
2407
Mentor
Ensign Mentor
Ensign
Posted: ‎2025-05-20 01:54 AM
Thank you Hennie Smith,
I created an application in the simatic manager and downloaded it, so it created a connection in the simatic net and now it works.
Best regards
