BMXP342020H problem
  • Industrial Automation
  • BMXP342020H problem
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
MAHMOUD_HASHEM
MAHMOUD_HASHEM
Cadet
Posted: ‎2025-11-15 04:40 AM
175
BMXP342020H problem
Hello
I need to add BMXP342020H
but I cant fount it in control expert  I just found BMXP342020
I use trial version
thank you
  • Edge Control
ciupol
Lt. Commander ciupol
Lt. Commander
Posted: ‎2025-11-18 10:53 AM
"H" (or "C") at the end of part number indicates hardened version of the module. Here is extract from the M340 catalog:
Functionally it is exactly the same module as the one without "H" (or "C").
You need to select BMXP342020 from the hardware catalog in Control Expert.
Hennie_Smith
Lieutenant Hennie_Smith Lieutenant
Lieutenant
Posted: ‎2025-11-18 08:35 PM
ECE does not distinguish between the standard and Hardened versions. Just use the standard version in your programme.
Hennie
