Control expert 14.1
  • Industrial Automation
  • Control expert 14.1
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
jakubmichalik00
jakubmichalik00 Cadet | EcoXpert Master
Posted: ‎2024-07-13 08:21 AM
6164
Control expert 14.1
Where can I download control expert v14.1?
Bosswaffle
Lt. Commander Bosswaffle
Lt. Commander
Posted: ‎2024-07-15 11:32 AM
In response to jakubmichalik00
2
6095
That's a good reason! I sent you a DM with a link.
Replies 12
Bosswaffle
Lt. Commander
Posted: ‎2024-07-13 08:38 PM
6133
14.1 is going to be difficult to find, at least at se.com and myschneider.com (the 2 places I looked). Why not use 15.3 or 16.0? They should be compatible. Someone else has pointed out here that you can even rename a .stu file to a .sta and open it in a newer version of Control Expert. If you don't have a file you should also be able to go online with your PLC and upload the program, no building necessary.
jakubmichalik00
Posted: ‎2024-07-14 12:30 AM . Last Modified: ‎2024-07-14 12:30 AM
In response to Bosswaffle
6121
Because I have license for 14
Bosswaffle
Lt. Commander
2
6096
darkenwald
Lieutenant | EcoXpert Master darkenwald Lieutenant | EcoXpert Master
Posted: ‎2024-07-24 11:22 AM
You can download it at the following links below:
ControlExpert_V14:
https://www.se.com/in/en/download/document/ControlExpert_V140_HF1/
ControlExpert_V15:
https://www.se.com/br/pt/download/document/CE_V15_SP1_Install_Procedure/
ControlExpert_V16:
https://www.se.com/uk/en/download/document/EcoStruxureControlExpert_V16.0/
Abeguerrero
Abeguerrero
Cadet
Posted: ‎2024-09-19 05:02 AM
Can you send a link to me as well I need a download link for 14.1 same reason have a license for 14.1.
Ricard
Lt. Commander Ricard Lt. Commander
Lt. Commander
Posted: ‎2024-09-19 11:38 PM
5769
Hello everyone
As the product progresses, some versions of Control Expert are no longer posted on the se.com website. At the moment, the versions shown in the screenshot are available.
If you need a specific version, the normal procedure would be to contact the technical support in your country, however you can always contact me privately and I will provide you with the version you need.
See you soon
Ricard
m_zubair_khan
Crewman m_zubair_khan
Crewman
Posted: ‎2025-04-03 02:37 AM
Can anyone provide me with 14.1 Link to download?
Ricard
Lt. Commander
Posted: ‎2025-04-04 12:06 AM
hello @m_zubair_khan
I recommend that you contact your country's technical support to request access to CE14.1. This is the safest option since you will know that it is from a reliable source.
BR
Ricard
pitt6630
pitt6630
Cadet
Posted: ‎2025-05-16 03:27 AM
Hi Bosswaffle, could you please provide me the same link in DM? Thanks.
keithkcchan
Ensign keithkcchan Ensign
Ensign
Posted: ‎2025-05-18 10:34 AM
In response to Ricard
Hi Ricard, I have trouble to find Control Expert v15.1 installation file, would you share the download link, Many Thanks, Keith
InacioTavares
InacioTavares
Cadet
Posted: ‎2025-10-02 04:56 AM
I was able to download it through the Chinese se version:
https://www.schneider-electric.cn/zh/download/document/EcostruxureControl_ExpertV14CN/
pratyush_prasanth
pratyush_prasanth
Cadet
Posted: ‎2025-11-19 11:13 PM
I would like to get the control expert v14.1 installation
