Posted: 2025-05-13 01:30 AM
Hello everyone,
I want to receive a signal from the digital output on the driver when the motor reaches the specified frequency. Is it possible to set this as a parameter?
Posted: 2025-05-13 10:23 PM
Yes that should ot be a problem. You could configer the decided Output on sRA alternative you could use Ftd
Posted: 2025-05-13 10:59 PM
Actually, I was planning to get the drive's 'ready' status from the relay output, which is why I initially wanted to get the 'frequency reached' status from the DQ+ output. However, I see that there are two relay outputs available. Therefore, I think I can get the 'ready' status from R1A and, as you also suggested, get the 'frequency reached' status from R2A.
Posted: 2025-05-14 10:59 PM
You could configor the Open Collector output in the same way like the relay output. The manual shows at first R1 but you could do for LO1 the same
