ATV320 motor current display to PLC
  • Industrial Automation
  • ATV320 motor current display to PLC
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
CSnape15
CSnape15
Cadet
Posted: ‎2025-01-18 01:11 PM
549
I am currently adjusting our system and would like to be able to display and adjust the current in which the VFD will show a fault through a PLC and HMI.
Is this possible to adjust/view on the ATV320's. My PLC I am using is a M251 with a magelis HMI. I am using ethernet IP communications.
Charlie
  • Connected Products
  • Training
Dotzauer
Crewman Dotzauer
Crewman
Posted: ‎2025-01-23 05:07 AM
Good day, I am usually using default mapping in industrial ethernet devices setting.
2. add it to devices scanner, output is for setting from PLC, input is for reading to PLC
3. map correct word to retain variable in PLC, inputs are from atv, outputs are to atv
I hope this is what you were looking for.
Best regards Jan.
