Modicon Edge I/O NTS - How to perform Bulk Firmware Update
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • Modicon Edge I/O NTS - How to perform Bulk Firmware Update
  • Mumuny_Gbadamosi
    Mumuny_Gbadamosi
Back to Industrial Automation Knowledge Base
Lieutenant Mumuny_Gbadamosi Lieutenant
‎2025-02-12 10:51 AM
Once a Modicon Edge I/O NTS distributed system is configured using the configurator or the web interface, the next step is to download the configuration into the target hardware. At this stage, there may be input/output modules that are part of the detected hardware using an older firmware version that is not compatible. To overcome this configuration mismatch, an update of the firmware of the existing modules is required.
The purpose of this article is to show how to perform bulk firmware update for input/output modules that are part of a Modicon Edge I/O NTS island using EcoStruxure Automation Device Maintenance.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Rate this article:
