Filtering network impact analysis
Impact simulation
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA: Capacity
  • Impact simulation
  • Filtering network impact analysis
  • Mark as Read
  • Simulating impact
  • Filtering and finding equipment in simulated impac...
  • Exporting impact table
  • Configuring simulated impact layout
  • Configuring cooling impact preferences
  • Simulating impact
EcoStruxure IT Support
Request Support
Back to Impact simulation
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-02 07:05 AM
You can filter your network impact analysis to include only the key elements of your setup, for example your main servers and internet access.
  1. Right-click the equipment and select Properties > Properties (custom).
  2. Type Network Marker in the Name column and define the equipment in the Text column, such as main server or internet access.
  3. Click OK.
  4. Repeat for other key elements.
You will only get simulated network analysis on the equipment with the Network Marker custom property. Simulated impact analysis on equipment other than the Network Markers will only include impact of power and/or cooling failure.
ITA_filtering_network_impact_analysis_360036715073.pngITA_filtering_network_impact_analysis_360036715073.png
ITA_filtering_network_impact_analysis_2_360036715073.pngITA_filtering_network_impact_analysis_2_360036715073.png
Note: To delete the Network Marker property, open Tools > Configure Custom Properties and right-click Network Marker in the Custom Properties table to delete it. It will not suffice to delete it in the equipment's right-click menu.
See also
Simulating impact
