Configuring simulated impact layout
Impact simulation
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA: Capacity
  • Impact simulation
  • Configuring simulated impact layout
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Impact simulation
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-02 02:31 AM
You can configure the layout of the Simulated Impact list to show equipment according to your preferences.
  • Click Configure Columns and select which columns to show.
  • Edit the column width:
    • Drag the boundary of a column header to the required position.
    • Double-click the boundary of a column header to make the column width fit to contents. Drag and drop columns in the list to move columns.
  • Click on a column header in the list to sort on this column.
  • Click on column header in the list to toggle sort order (ascending/descending).
Note: The simulation is only as accurate as the source information (the data provided in the data center model). A simulation, although a helpful and informative tool, may not be accurate and only shows eventual real effects.
See also
Simulating impact
Filtering and finding equipment in simulated impact list
Exporting impact table
Configuring cooling impact preferences
