Continue
  • My Subscriptions
  • Events
set and reset operators in structured text
HVAC and Pumping Forum
  • Industrial Automation
  • HVAC and Pumping Forum
  • set and reset operators in structured text
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
otrotabi
otrotabi
Contributor
Posted: ‎2022-08-04 07:21 AM
7067
what is the right way to use S (SET) and R (Reset) in HAVC ecostruxure machine expert ?
bool1 S= bool2 ; does not work, it gives syntax error.
  • HVAC
  • ecostruxure
  • hvac
  • TM171
  • TM172
Bastian_Schmitz
Champion
Posted: ‎2022-08-04 07:32 AM
7063
Hi, for my understandig S and R are more related to graphical languages like FBD and LD.
I think if you want do the same in ST you could use an IF THEN ELSE combination.
I could not find a sample in the online help or a way to use it in ST.
But if you use the SR/RS FB it should work.
Bastian_Schmitz
Champion
7063
otrotabi
otrotabi
Contributor
Posted: ‎2022-08-04 07:43 AM
In response to Bastian_Schmitz
Ok. I thought this was part of the IEC 61131 standard, but now I see  that in codesys it seems to be part of the extended standard (whatever that is it looks like not the standard implementation).
https://help.codesys.com/webapp/_cds_exst_operator_r;product=codesys;version=3.5.14.0
Thanks for your fast answer.
