filter fast digital input
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • filter fast digital input
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
otrotabi
otrotabi
Contributor
Posted: ‎2024-03-18 05:38 AM
2082
What it the easiest way to filter a fast digital input ? I am reading a turbine type flow meter on FDI1 and I would like to have a result that does not change permanently but is "averaged" every 10 seconds for example.
I think it is likely that there are some FB´s already developed for this use.
  • HVAC
  • ecostruxure
  • hvac
  • TM171
  • TM172
Bastian_Schmitz
Champion
Posted: ‎2024-03-18 02:10 PM
2065
Did you know OSCAT ? Based on this you could try one of the attached filter FBs.
The description of any of these Blocks is in the link above.
filter.zip
Replies 4
Bastian_Schmitz
Champion
2066
filter.zip
otrotabi
otrotabi
Contributor
Posted: ‎2024-03-21 10:50 AM
In response to Bastian_Schmitz
Yes. I remember you told me some time ago you were willing to import OSCAT´s functions to TM172 format, I guess this is part of your effort. Thank you for sharing it.
I tried to compile a very simple example:
I got this error:
FILTER_MAV_DW(13) - error S1305: INC1 => Unknown function
So I downloaded it from a Siemens forum, is this code ok ?
IF X >= N - 1 THEN
  INC1 := 0;
ELSE
  INC1 := X + 1;
END_IF;
(* this elegant version is 50% slower
INC1 := X := (x + 1) MOD N;
Is explicit dword to udint conversion as per my example needed or can I just :filter2.jpg
They both compile fine.
Bastian_Schmitz
Champion
Posted: ‎2024-03-24 01:08 PM
2012
The complex point on OSCAT is that a lot of functions use internal other functions of the Library. In that case I double check not this point. Attached the full conversion till yet. ~10% is tested, Use of own risk
ESME_HVAC_OSCAT_12_12_2023.zip
otrotabi
otrotabi
Contributor
Posted: ‎2024-03-26 03:57 AM
This is a Mastercard´s gift, it´s priceless 😊. Thank you.
If you would like me to help please do let me know. I will be happy to do it.
Regards
