Logging the BIOS and serial numbers of TM172E28R and TM172EVEV1U
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Logging the BIOS and serial numbers of TM172E28R and TM172EVEV1U
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
obscuresc
obscuresc
Troubleshooter
Posted: ‎2024-03-19 09:16 PM . Last Modified: ‎2024-03-19 09:17 PM
1089
I am using a TM172PDG18R (PLC) in conjunction with an IO expansion (TM172E28R) and a unipolar stepper driver (TM172EVEV1U).
I'd like to be able to log both the BIOS and serial number of all them via a single connection to the PLC. The stepper driver has the serial number listed in parameters, but not the BIOS. The expansion module has neither, likewise with the PLC.
How can I get access and read these parameters?
I am using EcoStruxure v1.5.0.
Cheers.
  • HVAC
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2024-03-21 01:50 AM
1069
unfortunately these info are not available.
You can only read them with ESME HVAC using a DMI connection (USB-ttl converter used to program M171O).
The FW of the I/O expansion is quite stable, I don't remember the last update.
FedericoM
FedericoM Mentor
Mentor
1070
obscuresc
obscuresc
Troubleshooter
Posted: ‎2024-03-21 06:12 PM
In response to FedericoM
Ok, cheers.
