TM173 information
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • TM173 information
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
otrotabi
otrotabi
Contributor
Posted: ‎2025-07-16 04:54 AM
1291
TM173 information
TM173 line is finally being introduced to our country and we are planning on using it for our chillers.
As far as I know, display has been enhanced and it shows two lines of information vs only one line in TM171 line.  I guess the OverwriteLocalDisplay FB works differently or there´s a different FB for the TM173.
I would also think the SmartBios library which used to work for the TM171 line has probably been updated.
How can we get this information ?
  • HVAC
  • ecostruxure
  • hvac
  • TM173
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2025-07-17 02:47 AM
here attached a training document.
SmartBios is no longer necessary, sysParameter target variable allows to manage all bios settings.
OverwriteLocalDisplay has been replaced by sysOverwriteSerialDisplay, but I would say that the best solutions is use multiple view from Configuration and Visibility type variables.
FedericoM
FedericoM Mentor
Mentor
otrotabi
otrotabi
Contributor
Posted: ‎2025-07-17 03:45 AM
Hi Federico. Yes, this should certainly get me started.
Thank you.
