TM171EP27R – SDO SET / Not Displaying in ESME-HVAC V1.7.0
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • TM171EP27R – SDO SET / Not Displaying in ESME-HVAC V1.7.0
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
StevenCho
StevenCho
Contributor
Posted: ‎2025-07-01 07:43 AM
705
Hi everyone,
I’m currently using the TM172PDG42RI in combination with the TM171EP27R.
In the past, this combination worked fine, aside from the relatively inconvenient configuration interface compared to other expansion modules.
However, I’m now facing a critical issue: the SDO SET list does not appear at all.
As you may know, configuring the analog input's min/max values and input type requires accessing the SDO SET list. Unfortunately, it is no longer visible.
At first, I suspected it might be an issue with my own PC. However, the same problem occurred on two additional PCs I own, as well as on three of my customers' PCs.
All the systems are running Windows 11, and the ESME-HVAC version is V1.7.0.
If anyone has encountered a similar issue or knows how to resolve this, your assistance would be greatly appreciated.
Thank you in advance.
Best regards,
Steven Cho
  • HVAC
  • ESME HVAC
  • TM171EP27R
Bastian_Schmitz
Champion
Posted: ‎2025-07-01 10:12 PM
This is a know issue regarding to windows 11 24H2. It could be solved with the follow registry file. You have to add them via doubleclick after unzip.
24H2_fix.zip
Bastian_Schmitz
Champion
24H2_fix.zip
StevenCho
StevenCho
Contributor
Posted: ‎2025-07-03 05:41 PM
Thank you for the solution!🙂
