TM171 date on screen
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • TM171 date on screen
FedericoM
FedericoM Mentor
112
Bastian_Schmitz
Bastian_Schmitz Champion
62
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
otrotabi
otrotabi
Contributor
Posted: ‎2022-07-22 11:15 AM
1990
I would not like to invent gunpowder again if I can help it ...
Is there a standard way to show a date on screen with TM171 ? Anything that would look similar to the way we change RTC showing Hour and date afterwards ?
https://www.youtube.com/watch?v=UFCYDB3BnvU&list=PLFqT6GhMpgpKziZxGdSaJPEEB1Q5i8Xo5&index=22
  • HVAC
  • ecostruxure
  • hvac
  • TM171
Replies 4
Bastian_Schmitz
Champion
Posted: ‎2022-07-24 10:59 PM
1939
If you want to show a time value based on Hours:Minutes you can define this as Format for Status or EEPROM Var.
IF you choose HH::mm as format the value will be automatically converted.
As example a screenshot of the simulation.
The value 180 will be shown as 03:00.
180 minutes = 3 hours
  • ESME HVAC
  • TM171O
otrotabi
otrotabi
Contributor
Posted: ‎2022-07-25 11:23 AM
In response to Bastian_Schmitz
1917
Thanks for your answer.
I came up with this program:
PROGRAM PRG_SHOWDATE
VAR
	usiret : USINT;
	ShowFlag : TON;
	ShowContent : TON;
	usiDisplay : USINT;
END_VAR
IF NOT ShowDate THEN
	RETURN;
END_IF;
ShowFlag(PT:= 1500);
ShowContent(PT:= 3000);
Case usiDisplay OF
	0: 	ShowDate := TRUE;
		ShowFlag(IN := TRUE);//Show flag
		ShowContent(IN := FALSE);
		IF  ShowFlag.Q THEN
			usiDisplay := 10;
		END_IF;
		sysLocalLeds[7] := 1;
		usiret:=OverwriteLocalDisplay(3,'TIME',0,0,0,1);
	10:	ShowContent(IN := TRUE);
		ShowFlag(IN := FALSE);
		IF ShowContent.Q THEN
			usiDisplay := 20;
		END_IF;
		usiret:=OverwriteLocalDisplay(3,'',TO_DINT(sysClock.hours * 100 + sysClock.minutes),2,0,0);
	20: ShowFlag(IN := TRUE);//Show flag
		IF ShowFlag.Q THEN
			usiDisplay := 30;
		END_IF;
		sysLocalLeds[7] := 0;
		usiret:=OverwriteLocalDisplay(3,'DATE',0,0,0,1);
	30:	ShowContent(IN := TRUE);
			usiDisplay := 40;
		END_IF;
		usiret:=OverwriteLocalDisplay(3,'',TO_DINT(sysClock.daymonth * 100 + sysClock.month),2,0,0);
	40: ShowFlag(IN := TRUE);//Show flag
		IF ShowFlag.Q THEN
			usiDisplay := 50;
		END_IF;
 		usiret:=OverwriteLocalDisplay(3,'YEAR',0,0,0,1);
	50:	ShowContent(IN := TRUE);
			usiDisplay := 99;
		END_IF;
		usiret:=OverwriteLocalDisplay(3,'',TO_DINT(sysClock.year) + 2000,0,0,0);
	99:	ShowContent(IN := FALSE);
		usiDisplay := 0;
		ShowDate := FALSE;
END_CASE;
ShowDate is a BOOL defined as Global variable and set somewhere else. It behaves pretty similar to what is shown when setting the time.  The colon symbol (:) is replaced by a dot but otherwise it should be pretty readable.
I tried to encapsulate this inside a Function Block but it looks like you can´t access the local display from within a function block, which sounds reasonable but I would like your comments on this subject please.
Bastian_Schmitz
Champion
Posted: ‎2022-07-25 11:30 AM
In response to otrotabi
1913
To acces a system variabel from an FB you need to declare these variabel as VAR_EXTERNAL in the FB. You can do this via drag and drop of the sysvariable to the declaration in table form.
otrotabi
otrotabi
Contributor
Posted: ‎2022-07-25 01:26 PM
Ok.But OverwriteLocalDisplay is not a system variable but a Function, so actually I can not drag and drop it on the variables section or instantiate it.
I thought maybe you meant the function output variable which is USINT type, but declaring that as external does not seem to change anything.
This function block will not complain, runs the timers, and sets usiret = 0 which indicates  command executed. Inñess this will actually run inside a real PLC (so far only on simulator).
FUNCTION_BLOCK DateDisplay
VAR
	ShowFlag : TON;
	ShowContent : TON;
	usiDisplay : USINT := 0;
END_VAR
VAR_INPUT
	DateInput : TypeDataTime;
	flagtime : UDINT := 0;
	ContentTime : UDINT;
END_VAR
VAR_EXTERNAL
	usiret : USINT;
END_VAR
ShowFlag(PT:= FlagTime);
ShowContent(PT:= ContentTime);
Case usiDisplay OF
		IF  ShowFlag.Q THEN
			usiDisplay := 10;
		END_IF;
		usiret:=OverwriteLocalDisplay(3,'HOUR',0,0,0,1);
			usiDisplay := 20;
		END_IF;
		usiret:=OverwriteLocalDisplay(3,'',SHL(DateInput.hours,2) + DateInput.minutes,0,0,0);
		IF ShowFlag.Q THEN
			usiDisplay := 30;
		END_IF;
			usiDisplay := 40;
		END_IF;
		usiret:=OverwriteLocalDisplay(3,'',SHL(DateInput.daymonth,2) + DateInput.month,0,0,0);
		IF ShowFlag.Q THEN
			usiDisplay := 50;
		END_IF;
			usiDisplay := 99;
		END_IF;
		usiret:=OverwriteLocalDisplay(3,'',DateInput.year + 2000,0,0,0);
		usiDisplay := 0;
		ShowingDate := FALSE;
END_CASE;
