Single pair ethernet
HVAC and Pumping Forum
Send InviteCancel
Posted: 2023-10-2309:55 AM
According to this blog SPE single pair ethernet is something worth looking at. I must say the idea of a single pair compared to the standard 4 pair ethernet connection sounds appealing.
Is it something worth looking at closely ? Does anyone have experience regarding what type of gateways are needed ?
I guess that this probably worsens the problem if Ethernet programming is what´s needed but maybe for webserver use the difference in speed might go unnoticed.
