M172P All-In-One USB Stick
HVAC and Pumping Forum
Send InviteCancel
Posted: 2023-10-2412:32 PM
Greetings!
It is useful to clarify one moment in creating "all-in-one" USB programming stick for M172P. Is there any parity in uploading files if I put both firmware and program files in same USB?
There are 2 expected behaviors (described in short):
1. (most likely) 2 cycles : Insert USB - upload firmware - reinsert USB - upload prog - BINGO! 2. (best for use) 1 cycle: insert USB - upload firmware - upload prog - remove usb - BINGO! 3. (unexpected) I have to use 2 different USB's.
Posted: 2023-10-2712:02 AM
for M172 we are in the case 3, M172 searches first for a bios so this has the priority (and after fw update M172 reboot so it will find again a bios update...).
