PLC M2XX and HMI with BACnet
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • PLC M2XX and HMI with BACnet
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
pawel_kowalski_
pawel_kowalski_
Troubleshooter
Posted: ‎2025-03-23 12:34 PM
1124
I have two questions:
  1. Is it possible to run the BACnet protocol on any of the 2XX series PLCs?
    If so, how can this be done?
  2. Do any of the HMI panels support BACnet?
Thanks in advance for your help.
  • Modicon M2xx
  • hmi
  • Mxx
Bastian_Schmitz
Champion
Posted: ‎2025-03-25 11:19 PM
The M2xx controller did not support BACnet. And so far I know the implimentation isn´t planned, because these controllers are Machine controllers and BACnet is a Building fieldbus. We support BACnet with TM172. On HMI site ET6 with Vijeo Designer Basic 2.0 support a little bit BACnet. Normal Vijeo Designer did not support BACnet.
Bastian_Schmitz
Champion
