Multilingual support TM172 HMI
HVAC and Pumping Forum
Showing results forย
Did you mean:ย
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Multilingual support TM172 HMI
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxureโ„ข Machine Expert - HVAC
otrotabi
otrotabi
Contributor
Posted: โ€Ž2025-06-16 05:54 AM
1149
How is multilingual support implemented in HMI ? I know it is by using string sets but I can not figure out how to do it.
A quick example will help.
  • HVAC
  • ecostruxure
  • hvac
  • TM171
  • TM172
FedericoM
FedericoM Mentor
Mentor
Posted: โ€Ž2025-06-18 11:42 PM
you can select the current language in this way:
@LocalParameters.Hmi_Language is a parameter aligned to sysLangId:
HowToCreateMultilanguageHMI_SC_Rev1.1.pptx
otrotabi
otrotabi
Contributor
Posted: โ€Ž2025-06-18 08:29 AM
Ok, I will settle for less than a working example ๐Ÿ™‚
From what I read in the programming manual, I should define two different string sets.
But then the page itself references one of them, as far as I know. The following picture is from the "Sets and Strings" example.
So, how is the reference to one or the other set made dynamically in the HMI ?
FedericoM
FedericoM Mentor
Mentor
otrotabi
otrotabi
Contributor
Posted: โ€Ž2025-06-23 03:43 AM
Hi @FedericoM! Thanks for the powerpoint. I think we all users wish this information was made available online somewhere. Add it on the to-do list please.
Best regards
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2026 Schneider Electric
