M172 with HMIET6400x
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • M172 with HMIET6400x
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Fanar_Ref
Fanar_Ref
Explorer
Posted: ‎2025-04-17 01:15 AM
1068
Hello!
I have a M172P 42I/O controller along with HMIET6400x. I want to simulate both plc and hmi to check data flow since I have no access to controller and HMI. The PLC when simulated runs TCPIP in local host 127.0.0.1:5000 but when i configure the same IP in HMI, it returns error. I tried changing the port number in HMI but still unable to establish connection. Is there any workaround to do this simulation?
  • HVAC
ismailozinan
ismailozinan Leader
Leader
Posted: ‎2025-04-20 10:50 PM
1018
Hi, If there is no TM172 hardware, in this case you need to modbus slave simulator. Because when we start ESME-HVAC software in simulation mod with , it does not have modbus simulation. if you have seperately modbus slave simulator, you can use Operator terminal expert software via 127.0.0.1.
StevenCho
StevenCho
Contributor
Posted: ‎2025-04-20 06:19 AM
As I know, Simulation between those two device is not supported.
If someone know the way, It would be very helpful🤣
ismailozinan
ismailozinan Leader
Leader
1019
Fanar_Ref
Fanar_Ref
Explorer
Posted: ‎2025-04-20 11:01 PM
In response to ismailozinan
Hello!
Thanks for the reply. Yes, after looking deep into the software, I found the simulator runs on gdb protocol unlike modbus. So, I'll try with modbus simulator since i dont have the controller with me.
