M172 - Logger and String Libraries
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • M172 - Logger and String Libraries
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
cloud_74
cloud_74
Explorer
Posted: ‎2022-05-18 04:13 PM
5
3067
Does anyone know where I can get a copy of the String and Logger libraries for EcoStuxure HVAC?
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2025-05-07 08:10 AM . Last Modified: ‎2025-05-07 08:40 AM
I'm not 100% sure about the library you are looking for, do you have a screenshot or something?
FS_IEC is available here:
C:\Program Files (x86)\Schneider Electric\EcoStruxureMachineExpertHVAC\Catalog\FreeAdvance\PLC
String library has been replaced by the embedded function available in the operators and blocks
StrLib.zip
Replies 5
LeTomas
LeTomas Mentor
Mentor
Posted: ‎2022-05-19 02:59 AM
HI @cloud_74 ,
I believe is the library FS_IEC.
Find attached an ooooold guide from Eliwell.
( I am not 100% sure if there is one for ESME HVAC)
Best regards,
LeTomas
Bastian_Schmitz
Champion
Posted: ‎2022-05-19 03:45 AM
3042
The Library File was included in the old release for Somachine HVAC.
In the newer release for Ecostruxure Machine expert HVAC these files are missing.
But you can still open the linked Library and rebuilt everything with copy an past into new FB/FCs.
Here is also a link for the two files
Link to Files
The included functions are used inside the Datalog FB for the easier creating of STRINGs from number values.
  • Datenlogger
  • hvac
  • TM172P
RichardGiesbrecht
RichardGiesbrecht
Explorer
Posted: ‎2025-05-06 01:28 PM
In response to Bastian_Schmitz
This link does not work.  Is there an alternative location?
FedericoM
FedericoM Mentor
Mentor
StrLib.zip
RichardGiesbrecht
RichardGiesbrecht
Explorer
Posted: ‎2025-05-13 09:30 AM
Thanks, I will look at this.
