M172 pulse generator
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • M172 pulse generator
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
POPE3909
POPE3909
Explorer
Posted: ‎2022-11-18 08:20 PM
1912
Hi Noobie here,
Is there any built-in pulse generator in M172 controller, I see there is R-trig but the ON period is too short. Or do I need to build one myself with timers to adjust the ON period?
Thanks in advance.
  • HVAC
otrotabi
otrotabi
Contributor
Posted: ‎2022-11-19 03:23 AM
1903
There´s a pulse generator available in the basic library. Here´s how to find it and use it.
Hope this helps.
otrotabi
otrotabi
Contributor
1904
Hope this helps.
Bastian_Schmitz
Champion
Posted: ‎2022-11-20 10:14 PM
In response to otrotabi
And as additional information for a better understanding.
TP creat "only" 1 Puls for  the time PT after EN get a TRUE.
Pulse create 1 Puls related to the value of periode and the number of tasks.
If you call Pulse in a timed task with a task time of 100ms the block will creat with a period input of 10 every 1s a true output.
POPE3909
POPE3909
Explorer
Posted: ‎2022-11-20 10:34 PM
This is exactly what I was looking for. Thank you.
