Posted: 2023-06-04 11:26 PM
1. How to show data time on the graph in Vijeo Designer ?
2. It is possible to show units of value on the graph?
Posted: 2023-06-05 12:25 AM
I believe you need to use an "Historical Trend" rather than the normal "Trend", see below the example:
For the unit i just added a plain text in the border, I am not 100% sure if we can do that in the normal trend or in this historical trend.
Best regards,
LeTomas
Posted: 2023-06-05 11:45 PM
Thanks, @LeTomas for your advice I check it.
I have another question about how to show on HMI, UDINT 32bits variable
At first how to send that value (32bits) through modbus TCP using 2 WORD registers.
Second how to show that value on HMI.
I will try to do this in that way because I don't know how to send variables using 2 words :
1. Create a variable in PLC eg. %MD1 and assign to them 32bit variable.
2. On Vijeo Designer I have that settings:
After doing it that way HMI displayed 0 but on PLC app value is correct.
I using Machine Expert v 2.1, Vijeo Designer, and HMI is the same as the beginning topic.
Posted: 2023-06-06 03:04 AM
Hi @pawel_kowalski_ ,
I believe i explained in a previous post but maybe it was not clear enough.
Please check the next video:
Best regards,
LeTomas
Posted: 2023-06-12 12:08 AM
After starting PLC the value was shown property in Machine Expert
In Vijeo Designer configuration below
Give me know what I can check to resolve that problem.
Posted: 2023-06-12 03:01 AM
Attached you can find an excel file that allows you to import the variables from SoMachine/Machine Expert to Vijeo Designer without using the symbol configurator. Give it a try and let me know.
Best regards,
LeTomas
