Check communication with Modbus Serial (RTU) Slave
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Check communication with Modbus Serial (RTU) Slave
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
pawel_kowalski_
pawel_kowalski_
Troubleshooter
Posted: ‎2023-06-11 11:23 PM
2729
As I wrote in the topic now I need some advice on how to check communication with modbus slave device.
Configuration what I have is below in the picture:
I searched tabs like in Modbus TCP where were Healthbits but in Serial probably it doesn't exist.
I try to use FB like IODrvModbusSerial where variable xAllSlavesOk shows FALSE and another variable uiNumberOfCommunicatingSlaves shows 0.
Maybe I using that FB wrong and that is why the variables show FALSE and 0.
  • Modicon M2xx
  • check communication
  • modbus rtu
  • Modbus Serial Line
  • Modbus Slave
LeTomas
LeTomas Mentor
Mentor
Posted: ‎2023-06-12 02:57 AM
Hi @pawel_kowalski_
The ModbusSerial Device has their own structure, you can use the "Slave Name".xError to show that the device is disconnected or has another problem:
Best regards,
LeTomas
LeTomas
LeTomas Mentor
Mentor
Hi @pawel_kowalski_
Best regards,
LeTomas
