Establishing client state Modbus TCP connections when M172 is a server
HVAC and Pumping Forum
Send InviteCancel
Posted: 2022-08-1407:58 PM
Hi all,
I'm using the M172PDG18R.
If I using a Modbus RTU client, I can see from the M172 side that the client is correctly communicating by using the 'sysMODBUS_msg_received_RS485_1' parameter.
Is there a similar feature, or another method I can use for observing the Modbus TCP interface when the M172 is a server?
