Error Generating USB Programming files
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Error Generating USB Programming files
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
sardila
sardila
Contributor
Posted: ‎2022-07-07 06:00 PM
2119
I recently Updated the EcoStruxture Machine Expert  version to the latest one 1.4.0 and the target bios to 668.12 firmware version.
Now, I am getting errors traying to generate the USB programming files:
File C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_7IO\PARAM.DAT and C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_7IO\PARAM.RAW correctly generated
Error generating file C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_7IO\PARAM.BIN
USB folder generated: C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_7IO
File C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_18IO\PARAM.DAT and C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_18IO\PARAM.RAW correctly generated
Error generating file C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_18IO\PARAM.BIN
USB folder generated: C:\Users\sardila\Documents\repository\89r-cw-h-plc-code\USBCWH2020_18IO
Anyone have had this issue before?
I much appreciate any suggestion, Thanks.
  • HVAC
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2022-07-07 11:57 PM
2102
this is a known bug of version 1.4.0 with target 7/18 I/O.
You can fix it with the patch you can find at this link:
https://schneider-electric.box.com/s/svi3uam9raimwf51srhf70zv3idbup10
Bastian_Schmitz
Champion
Posted: ‎2022-07-07 10:01 PM
If you update the target in a project and you get this error try the function "Refresh current target"
  • ESME HVAC
FedericoM
FedericoM Mentor
Mentor
2103
sardila
sardila
Contributor
Posted: ‎2022-07-10 05:01 PM
In response to FedericoM
Thanks, I much appreciated it.
The bug was fixed!
