Posted: 2022-05-27 09:09 AM . Last Modified: 2022-05-27 09:22 AM
Hi All,
Our customers are looking to use our product with Machine Expert. I am in the process of building a library to simplify implementation and usage.
Mark
Posted: 2022-05-27 11:36 AM
I believe I answered my own question. Use the word INTERNAL.
Example:
VAR_GLOBAL INTERNAL
test : INT := 5;
END_VAR
This GVL is now not exposed outside of the library.
Example:
VAR_GLOBAL INTERNAL
test : INT := 5;
END_VAR
Posted: 2025-01-06 07:38 AM
Hi.. Mark I have tried to implement your solution.
Where I have multiple blocks that would influence each other I was planning to create a GVL and route all the variables through it. But When I tried to create a VAR_GLOBAL INTERNAL as mentioned by you. My POUs which are some FBs not recognizing the global variable
Eg:
VAR_GLOBAL INTERNAL
test : INT := 5;
END_VAR
