TM172 How to enable Ethernet to use BACnet IP
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • TM172 How to enable Ethernet to use BACnet IP
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Eddie.Li
Eddie.Li
Explorer
Posted: ‎2025-01-06 01:42 PM
2112
I have a TM172PBG18R, and I'm trying to configure the Ethernet to use BACnet IP. However, I couldn't find the option under Configuration > M172 07-18 I/Os > Ethernet.
The manual mentions that this feature is disabled by default, so I’d like to know how to enable it. Also, would I need some sort of BACnet library to program it in Ecostruxure Machine Expert HVAC?
I'm new to PLC development, so I apologize if this is a basic question.
Thank you!
  • Connectivity
  • HVAC
  • bacnet
  • M172
Bastian_Schmitz
Champion
Posted: ‎2025-01-07 10:20 PM
Hi, This is the value you are looking for
You have to set the value to 0 to activate the BACnet IP Port
Bastian_Schmitz
Champion
