Continue
  • My Subscriptions
  • Events
Creating Library Help
HVAC and Pumping Forum
  • Industrial Automation
  • HVAC and Pumping Forum
  • Re: Creating Library Help
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Anonymous user
Not applicable
Posted: ‎2022-05-27 09:09 AM . Last Modified: ‎2022-05-27 09:22 AM
2
2439
Hi All,
Our customers are looking to use our product with Machine Expert. I am in the process of building a library to simplify implementation and usage.
  1. Is there a help or tutorial to review which may help with best practices etc?
  2. I have multiple function blocks that can influence each other. Is there a way to share variables without them being visible to the user? I can easily create a structure that has what I need but I don't want it seen by the user. Essentially looking for the equivalent to an internal variable in a dll.
Mark
Anonymous user
Not applicable
Posted: ‎2022-05-27 11:36 AM
1
2427
I believe I answered my own question. Use the word INTERNAL.
Example:
VAR_GLOBAL INTERNAL
test : INT := 5;
END_VAR
This GVL is now not exposed outside of the library.
Replies 2
Anonymous user
Not applicable
1
2428
Example:
VAR_GLOBAL INTERNAL
test : INT := 5;
END_VAR
nabinz
nabinz
Explorer
Posted: ‎2025-01-06 07:38 AM
In response to Anonymous user
Hi.. Mark I have tried to implement your solution.
Where I have multiple blocks that would influence each other I was planning to create a GVL and route all the variables through it. But When I tried to create a VAR_GLOBAL INTERNAL as mentioned by you. My POUs which are some FBs not recognizing the global variable
Eg:
VAR_GLOBAL INTERNAL
test : INT := 5;
END_VAR
