Changing BACnet Instance Numbers on M172
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Changing BACnet Instance Numbers on M172
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Aribbs
Aribbs
Explorer
Posted: ‎2025-12-09 02:05 AM
420
I'm looking to program an M172 to be a direct replacement for another PLC which has certain BACnet object instances. When I try to change this in machine expert, the option is greyed out and I cannot change this.
Is there any way to change the BACnet object instance number?
  • HVAC
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2025-12-10 12:18 AM
It's not possible, the instance can be changed only on the Device object, the instance of the other objects AV, BV,... objects is automatically assigned starting from the lowest one
FedericoM
FedericoM Mentor
Mentor
