Posted: 2025-11-14 02:03 AM
Hi Team,
I am Using PLC-M172 and HMI-HMIET6400.
Now here I am reading the some flow meter data and i prepared the totalizer of it.
now I want to make it retentive and EEPROM have some limit.
so can you help me for retaining this data as well I have some pump running time also want to retain.
regards,
chandraprakash
Posted: 2025-12-10 12:22 AM
TM172 has just 1 retain DWORD, you can use it mapping a DWORD on datablock 102.0
If you need more, data should be saved into EEprom every hour or half an hour.
TM173O has more RETAIN data, on this controller you can declare it using RETAIN attribute
Posted: 2025-12-01 12:22 AM
To use retain, I apply two independent methods, one on the HMI side and one on the PLC side. I’ve shared both in the attachment; they may be helpful.
Wishing you good work.
Posted: 2026-01-05 11:34 PM
An alternative could be that you save once a our via syswriteparUDINT the measured value to the epprom. Like the hour counter block.
