Analog output type
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Analog output type
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
otrotabi
otrotabi
Contributor
Posted: ‎2025-05-28 06:52 AM
824
Analog output type
Rookie question: analog outputs at least for TM172 series are either 0-10VCC , 4-20 ma , PWM or ON-OFF. So why is the type INT ? And what happens if output is set to i.e. -5.3 VCC ?
  • HVAC
  • ecostruxure
  • hvac
  • TM172
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2025-05-29 02:21 AM
I've checked, with M172P, it's better to limit values to positive ones.
A negative value it's like to write 1000.
A positive value, bigger than 1000, it's limited by bios to 1000.
TM173O instead performs an internal limitation between 0 and 1000
FedericoM
FedericoM Mentor
Mentor
otrotabi
otrotabi
Contributor
Posted: ‎2025-05-30 04:02 AM
Thanks Federico !
