ZBRN32 documentation
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • ZBRN32 documentation
Romain_Polette
Kirk Romain_Polette Kirk
116
Guillaume_Evrard
58
Randi_Dolan
46
CharlesV
CharlesV
Cadet
Posted: ‎2023-11-07 11:01 PM
2567
I hope this question is on the correct group. If not, please help me to find the correct one.
I have a ZBRN32 which I am using as a WAP for TH110 and CL110 sensors. I am using the documentantion from the ZBRN1 and 2 but have found that there are differences between them and the 32 in the modbus mapping. I am connected with ModbusRTU and am able to get responses from the device.
It seems (for example) that the Radio Channel has moved from Register Address 4024 to 4018.
A second problem that I have is the the wirless signal strength is zero (and the led indicates that as well) although the configuration indicates that it is RUNning. I have paired 3 CL110s but the data I read seems to indicate that they are not being read.
a. Can someone help with the ZBRN32 manual.
b. If not, does anybody know what I am doing wrong ?
regards
Charles.
  • troubleshooting
Tags (2)
  • ZBRN32
Romain_Polette
Kirk
Posted: ‎2023-11-08 04:54 AM
2562
Hello @CharlesV ,
ZBRN32 is not a gateway supported by this community.
However, check these threads to have some help:
  • https://community.se.com/t5/Gateways-and-Energy-Servers/How-to-get-Modbus-register-of-the-Wireless-T...
  • https://community.se.com/t5/Gateways-and-Energy-Servers/ZBRN32-configuration-TH110-pairing/m-p/40469...
Romain POLETTE
Solution Architect - France Operations
CharlesV
CharlesV
Cadet
Posted: ‎2023-11-08 11:41 PM
2554
Hello Romain,
Thank you for the reply.
Do you know where I might find the right group to get some support ?
regards,
Charles.
Guillaume_Evrard
Captain
Posted: ‎2023-11-09 08:46 PM . Last Modified: ‎2023-11-09 08:50 PM
If you are using the latest FW ZBRN32 should behave similarly as ZBRN1/2. ZBRN1/2 documentation is available on se.com as true SE industry product. For support you have to get in touch with SE.
There is one big difference with Timeout for TH/CL. ZBRN32 will keep the last measurement received and you have to handle the timeout. ZBRN1/2 will provide NaN in case of timeout.
ZBRN32 is mandatory for SMD MV, I am recommending the use of ZBRN1/2 rather than ZBRN32 if you do not have SMD MV.
PAS or PTL support also TH/CL as Zigbee Gateway.
Kind Regards
